Mine also makes a groaning noise only when turning left..
Mine too, although it seems to happen more when going uphill, when you have to add a small amount of throttle. Actually, you can provoke the groan by accelerating very gently and turning left slightly... never fails...
I changed the PAS oil, and it made quite a difference to the pump noise when cold, also gave more braking and steering assistance. (I'm sure it's not my imagination)
I also tried WD40 on the belt,(and it worked) careful to keep it away from the cam belt- not sure I would want wd on that!!
I had a coupe for 12 years and in the winter pump was noisy,and summer it was quite. +sprayed with wd40 which works.Always said i wanted to replace when it died but it lasted the 12 years i owned it with no operational issues.changing steering fluid helps too.
