rs2 engine problem!(help)
    Originally posted by Rusty
    Anyone mentioned the throttle position sensor? I've forgotten to plug it in before and had nearly identical symptoms. Might be the extension wiring is back to front...
    Agree. I have done that too. Simple to check and fix.
    • fatiii
      • Nov 2010
      • 130
      • Country: Turkey
      #92
      how long distance have been between volant tooths and sensor
      • fatiii
        • Nov 2010
        • 130
        • Country: Turkey
        #93
        this curvature is a normal?
        Editk it is normaly
        • fatiii
          • Nov 2010
          • 130
          • Country: Turkey
          #94
          Originally posted by Nuno Cristiano
          Send me your config file to: Info@chip-fuse.pt
          send it.
          Originally posted by A80Avant
          yes i also do that everytime i have a problem as well.
          fatii: send the config to someone. The first thing i would check is the fueling map as it may be that there is not enough fuel when the throttle is pressed and therefore it stalls.
          then i could start thinking other things. When vems was fitted, did anyone check the timing marks with a strobe light? Have you changed the VR sensor cable as should be done? Have lamda and IAT sensor and TPS sensor been calibrated? etc etc etc
          I need your mail A80Avant
          • stocious
            • Jul 2012
            • 838
            Hey fattiii, your car is sweet, it's yours, all that matters !!! Best luck getting it going !! Won't matter what's stamped on engine when I fires up one mans junk is another mans treasure !! I have 3 b too
            1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
            • fatiii
              • Nov 2010
              • 130
              • Country: Turkey
              #96
              any idea?
                Detailed Crank Position Pin Info
                Have a look at the diagram below and read this post:
                • AndyP
                  • 6049
                  any idea?
                  The sensor on the flywheel teeth is 0.5-1.25mm. The one that picks up on the small single pin is 0.45-1.25mm.
                  • fatiii
                    • Nov 2010
                    • 130
                    • Country: Turkey
                    #99
                    thank you so much
                    • AndyP
                      • 6049
                      I must learn how to convert PDF's to JPG's
                        G4 crank position and G28 engine speed sender info
                        Have a look at the photo below and read this post:
                        Your's seem not so long compared to these. (see my other post re: distances)
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            #103
                            I had a look at the config and I must say that it must be a combination of things. The basic settings seem ok but the maps are decently horrible.
                            You need to upgrade the firmware to the at least stable 1.1.95 and make sure you use a strobe light to check the timing angle that it corresponds to vems. Then I have made some changes to the map but I have sent an email to find out some info for the engine specs before I continue.
                            Whoever decides to go vems they MUST get involved and not rely on a tuner who knows generic stuff. Whoever put values on this map either wasn't interested in the car or didn't know a lot of info. Please read about what you can do and we will try and help you as much as possible.
                            The crank sensor needs to be as close as possible without fouling the pins. If it still doesn't work then you need to weld a larger pin by copying the size and length of the original dual mass flywheel pin
                            • Nuno Cristiano
                              • Aug 2010
                              • 421
                              • Country: Portugal
                              #104
                              I also got the config file and not by what is done there that the car will have that problem. If you look good is constantly trigger errors. Any problem with VR sensors.
                              The tables must be done correctly, but I repeat that what is there, must work properly and do not turn off the car as it appears in the video.
                              .: MINI Cooper D 08' :.
                              .: Audi Coupe Quattro 20V 91' :.
                              .: Audi Porsche RS2 95' :.
                              • A80Avant
                                • Sep 2005
                                • 10873
                                • Country: Greece
                                #105
                                The only way to find out is to make sure the car has an ecu that is properly configured and doesn't have all those config validation errors. Only then you can say its the crank sensor
