But is yours the original engine that came out of the factory fitted to this exact car? if not then I don't consider your car a rs2 as its not how it left the factory (even with the exception of modifications)
Question for you - all these cars with 7a heads on them because they are generally in better condition than adu/aby/3b heads with no cracks etc. If the original heads are too far gone and the only financial alternative is a 7a head does this make them any worse as the heads are better but they are not stamped like the originals.
I'd rather have the better 7a head than a cracked and potentially an expensive failure original head.
