Charge the battery, that won't help if its low and slow turning over.
I guess you have already checked if there is any boost leaks? I know there is no MAF on Vems but it seems to have the same symptoms.
And my 2p about if its an rs2 or not!
It is an RS2! With an upgraded inlet, upgraded turbo etc. who cares if the block code is RR,3B,AAN,ABY,ADU
Johnny has an original ADU engine in his 3B coupe does that make it an RS2 coupe???
0-200km/h 9sec
