RR plot
  • karlblues2
    • Jul 2004
    • 402
    • Home: England Current: Australia
    Originally posted by Mihnea
    @karl: Star Performance wish they had written S2 chipsets. What you have is probably done by one of their friends (I won't say any names), but Doug's sure wasn't done by them, we have only used their dyno to measure the power/torque.
    Mihnea
    Yes, you're right Mihnea. I recall it was written by a guy who used to work at AMD and wrote their chipsets 'apparently'. It's ok, but spool up time and boost is not that much above standard to be honest. I would like you to PM me (I thought you were away for 2 weeks!~!!?) with a cost for the chip with the turbo etc we spoke about.
    Karl
    Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
    Audi 90 Quattro 20V 1989 7A
    Audi TTRS 2010 APR stage 2 +
    Triumph 675 Street Triple R
    • karlblues2
      • Jul 2004
      • 402
      Originally posted by Doug_RS2
      Go faster parts:
      Arrow Rods
      Custom JE Pistons
      Twin Headgaskets 8.0:1 CR
      Headwork
      Standard Bosch Plugs
      ARP Head Studs
      ITG Filter 180x210
      Descreened ABY MAF
      3" Inlet pipework
      Huge IC
      AAN Inlet Manifold, modified so front entry
      600cc injectors
      Standard ABY FPR
      Bosch Motorsport Fuel Pump
      RS2 EM
      K26/27 Hybrid Turbo
      Seperate Wastgate Exhaust
      3" Marco Downpipe
      Front section of exhaust is 3" and goes down to 2.5"
      No Cats
      Custom Mapping from Mihnea
      VMAP so boost is controlled above 2 Bar
      Breather Catch Tank
      I have probably forgotten some bits.
      Wow...!!! Thanks Doug. That's a shopping list and a half! How much difference do you think a 2" DP from the wastegate would make? And (stupid question) if it's separate, where does it join the main DP?
      • Doug_RS2
        • 3847
        Geoff at AMD used to do the S2/RS2s - although my chips never had the knock sensors on
        The seperate wastgate DP does not rejoin the exhaust. Mine and Toms points out the bottom of the car - this is ok as the car will always be moving when the wastgate is modulating - although on the RR you burn the paint off the rolling road
        It must be working hard at high rpm, as it glows red - it also means you can get uninterupted flow out your turbo down your main downpipe.
        • karlblues2
          • Jul 2004
          • 402
          TeeHee. Thanks Doug. That'll be my next mod then with my friendly exhaust centre. (They love experimenting with my car at little if any cost to me??!!)
          Lack of knock sensors...ouch. Mine has them AFAIK as I can here them coming in occasionally
          • audiman
            • 4827
            bLAH, BLAH, BLAH, Yes my first run was pathetic 280bhp!! I'll try and scan my laminated dyno plot here at work and post it up
            Tom C - www.rcmr.co.uk
            Audi UR Quattro
            Audi 100 C3 2.0 5 cyl 115ps
            Audi B5 RS4 645ps 911nm
            • audiman
              • 4827
              Here it is!! And thats with crap cooling. Approx gain with correct cooling is 30bhp more.
              Audi UR Quattro
                The sooner you two can have another RR shoot-out the better!
                LOL, going be blood on the forum floor at this rate!
                • Pete_RS2
                  • 800
                  #23
                  Any chance of a ride in Tom & Doug's beasts at the next meet ?
                  Now RS2'less
                  '99 VW Passat VR5 Sport
                    I'll have your keys whilst your doing that then! :mischeif:
                    • Pete_RS2
                      • 800
                      #25
                      LOL. I didn't think you needed keys Jamo. I've seen that "shifty" look before....
                      Now RS2'less
                      • S2 Ant
                        • 3682
                        Can def confirm that both cars are beasts!!!
                        Got a real thirst for power now!!!
                        Ant
                        2011 Kawasaki Z1000
                          Ah Touché! Stiched up like a kipper!!!
                          Aint got no come back to that
                          • S2sedan
                            • Aug 2004
                            • 189
                            #28
                            is that correct ???
                            320 hp at wheels ???
                            what kind of boost are you running ???
                            If thats correct I don´t think thats pretty much, when here in Brazil are a lot of golfs gti only with small upgrades without internals with 300 whps and some 320 whps. with only 1.4 bar in K16 turbos running ethanol.
                            S2 Limo sold !!!
                            M5 E34 with some mods in the garage
                            sorry, but much happeir now !
                            • s2audi
                              • May 2004
                              • 45
                              #29
                              AWD golf GTis ?
                                Originally posted by S2sedan
                                is that correct ???
                                Golfs dont have 25% or greater transmission loss of the 4wd S2
