Originally posted by audiman
What DV to buy? - RS2
Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
Good idea Matt. Should make a nice little improvement to the noise!!sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
Originally posted by S2central.netStandard Audi / Bosch part for S3 (ess THREE) is plenty good. Its alleged to have a tougher diaphragm than S2/RS2 item. Straight replacement.
paul
does someone have the part number for this Audi or Bosch S3 dv?
thanx
i have emailed a company who supply forge stuff and they have said they contacted forge and they recommend this one for the S2, is this right?
forge dvTim
1995 S2 Avant, ruby red - ** SOLD TO ROSS **
Golf Rallye G60 ** SOLD **
Golf MK2 Oaky with R32 engine
Audi A6 Avant 1.9 TDi 130
Golf MK2 8v Race car
mine is the 006 type. It still is piston but it can be seviced and springs can be changed etc. I dont think you can open the 007 up. ........... I thinkDAVIDP20V - 95' Polar Silver RS2 standard 315 bhp, forge diverter valve, Mark H mod and boost gauge..... and shes for sale.
006 is a piston type. This is what I use but mounted in a reversed configuration. 007 is the same but with a cap that unscrews from the main body for servicing as opposed to both halves held together with allen bolts. Neither of these is diaphragm type and should be fitted with the newer ally piston as opposed to the early plastic one. 007 is smaller than the 006 and that is the only difference.
Very reliable hardware and has seen 30k miles without service. Forge customer service is second to none too. There are also a new range of fast-acting diaphragm valves from Forge now.
I can offer discounts on Forge products if required.
Lee1995 S2 Avant with some upgrades
Designun Limited....
Originally posted by Lee006 is a piston type. This is what I use but mounted in a reversed configuration. 007 is the same but with a cap that unscrews from the main body for servicing as opposed to both halves held together with allen bolts. Neither of these is diaphragm type and should be fitted with the newer ally piston as opposed to the early plastic one. 007 is smaller than the 006 and that is the only difference.
Lee
Lee has his fingers in everything!
Well problem solved buy of Lee!
Lee, why did You use it in a reversed configuration ?
I should use the 006 type (what P.N. ? exactly is it?) or 007 ? The 007 is with unscrew bolts? What happens when I put a stronger spring into it ?
Thanx for answers !
Mine is this dual pistons... (bur silver)
Pretty noise!Audi 100 TDI :mischeif:
MRC remap; Green Injectors; Champion Sparks; Forge DV 006; Samco Intake pipes; K&N filter
Xenon 6500k; Pillar Boost gauge; Alpine CDA 9835R on Bose with Infinity Sub
Oettinger 8x18" with GS-D3 225/40ZR18; Bilstein with H&R Springs (-40mm)
www.autopamplona.com
www.mrctuning.com
