Help....ECU fault codes!
That would be useful. I'm still crap with electrics though and it's a total nightmare to get up to the fusebox in the S2! The wiring is a mess since it's had a couple of alarms/immobilisers fitted over the years.91 Modded 3B
14 A6 Avant Black EditionComment
Dash out. It's a hour of work and you can then get everything sorted... as you saw with mine. Maybe not...
I'll give you a hand, plenty of spannering to do on mine in the next few weeks, so will work out nicely I'd say
Fused relay sounds like the best option IMO.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
Steve I made my own loom for my electric recaros it is actually a really simple circuit - literally just a positive connection from the fuseboard with an inline thermo-fuse and a ground.
The electric seats are supposed to take a direct 30a feed from the fuse board, same position on the fuse board as the heated seats (where I indicated to you on that picture
The electric seats do not have a typical fuse, they use a 30A thermo fuse, one for each seat - same type as the electric windows.
What you need to do is make a pig-tail to take a feed from the fuse board and split it into 2 x 30a feeds for the seats (one for the electric adjustment and one for the heating) so they don't interfere with anything else
Imola B6 S4 AvantComment
Yes, but it's more like boost limiting from seat control...
