Do you read wiring diagrams?
1.8 turbo wont start , no spark on coils neither fuel pumps works help please
IF you cannot connect to the engine hence you have a problem with ecu or supply to the ecu. You can check the 12V , GND and the 12V supply through ignition . If all are ok you have something wrong in the ecu.Audi S4 2.2T 5 spd 1992 for parts
AUDI A4 1.9TDI daily use
Audi 80 Quattro 2.0 16V (ACE) aka CompetitionComment
Pin 62 from ECU you should have 12 V . Pin 3 you should have 12 V with IGNITION ON.
PIn 1 and 2 you have ground.
Check all the wire using a bulb of 21 W .Audi S4 2.2T 5 spd 1992 for parts
THe witing harness for 1.8 T is fairly the same on cars with drive by wire throttle . So you won't do anything wrong. USe the AUQ wiring from Autodata. Good luck!Audi S4 2.2T 5 spd 1992 for parts
