Hello guys,
I´m having a rough time reassembling my ADU after changing the head gasket. When reassembling it, I verifyed the both marks on camshafts aligned, as well as the sprocket mark with the head. After haveing all those aligned, I moved the sprocket one tooth in retard, so as should be in ADU, right?
Doing that, I´m getting G40 Hall sender mechanical fault on the diagnosis, and the car won´t start. I tryed, then, aligning the mark on the sprocket with the head, and I can get the car to start, but I start getting fault signal from G28.
I have tried looking for threads on this subject, for I sure I´m not the first one asking about this, but the info seems to be conflicting. Plus, many times, people refer to AAN, and we know ADU has different timing complications, right? Please, any info on thet subject will be most appreciated, for I really seem to be out of options here.
Best regards from sunny Rio
