Welded flywheel timing pin
  • AndyP
    • 6049
    Has anybody got first hand experience of welding a new timing pin to the flywheel through the starter motor hole?
    I have this to do and I've heard it can be done like this, but the access you have appears to be almost non-existant
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    Is it the same mod as vems users needs to do ?
    • GazzaG60
      • 4133
      I presume we are talking single mass here. presume you would get a fraction more space.
      mega small hands and welding gear?
      • GT500
        • Jun 2006
        • 2181
        Done it before. Mr Tig sorted it!
        Rob..
        87 UR 20v ABY
        97 S6 Avant
          Here are a couple of examples:
          The latter one shaped the additional pin based on this (based on dimensions provided by V6quattro from here):
          • merlin's S4
            • Jan 2005
            • 1539
            I had the pin welded back into place after it fell off. It was possible to weld it through the starter hole, although not easy. The pin was tacked to a flat metal bar which we bent so that I could hold the pin in place from the top of the engine bay whilst my welder friend welded it back on to the flywheel.
            • stocious
              • Jul 2012
              • 838
              where do you put the earth strap?
              1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
              • AndyP
                • 6049
                Made a new pin based on the dimension in Dave's post above
                Going to try and get some weight out of it so it does not screw up the balance of the engine.
                This is my plan, hold the new pin inplace with a small magnet while I get the first tack on. This is a stock 3B flywheel with pin in place.
                Now to practice welding with my eyes shut! I think if I can get a decent tack like this either side it should be fine.
                I'm going to try and get the earth strap on the flywheel through the timing hole on the oposite side of the bellhousing.
                • quattro turbo 550bhp
                  • Nov 2009
                  • 416
                  • Home: Pakistan Current: United Kingdom
                  fly wheel pin
                  i had this done on my 20v rr quatt it stood for 3yrs b4 bless him mr p payne found problem as it had a chippd mtm chip in it so it was not bringing up the flywheel sensor code up so no one checked it so a few mechanics rippd put the alarm then seperate immobiliser then half of dash saying its got elect prob then ecu faulty as it had no spark etc until the late mr p took out the starter & found prob but i got another flywheel ready for him to change its a dog of a job as mine had snapped in the flywheel & not fallen out so it was much much harder just to do it in situ through the starter hole as it had to be drilled out etc so can be done so good luck sir
                    This is what S4Pirate on my home forum did last week (based on the same post I linked you to) (2 photos make sure you see the last one):
                    And this, which is the key point, he drilled the new pin to fit over the old pin so placement of the new pin was less of an issue.
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      That's a very nice idea.
                      Andy can you make 2 pins like that? That may solve in the future my vems trigger errors!
                        After seeing this I think I will give mine a squirt with the TIG before I send it off for balancing in a few weeks.
                          I have been advocating pre-emptive additional welding on the G4 Timing pin for some years now, after several documented stories of the pin coming off the stock DMFW with time.
                          Note Paul N's recommendation about unplugging the battery, the ECU and ABS computer before firing up the welder.
                          • AndyP
                            • 6049
                            Well here's the culprit
                            As my flywheel has been lightened I was able to take some more material off the new pin as it didn't need to be as big
                            Looking at this pic I need to spend more time cleaning the flywheel to make welding easier, and I need to make a better job of centreing it!
                            Also need to look at getting a smaller TIG torch to make access easier as there is virtually none at the moment using the torch I have
                            Only going to get one shot at this so I want to make sure everything is right before I commit to welding.
                              ..As my flywheel has been lightened I was able to take some more material off the new pin as it didn't need to be as big....
                              ... and I need to make a better job of centreing it!
                              Also need to look at getting a smaller TIG torch to make access easier as there is virtually none at the moment using the torch I have.
                              1. Not following your lightened flywheel = okay to have a smaller pin. It is a pin that is too small that is causing you grief now.
                              2. In the examples I think I gave, the bigger pin was drilled so that if fit over the round pin (which one assumes was in the correct location).
                              3. Doesn't anybody remember arc-welding rods? They are long and only about 1/8" diameter. Very easy to get in there with welding rods. Wire-feed welders aren't the solution to all problems.
                              Just saying...
