The latter one shaped the additional pin based on this (based on dimensions provided by V6quattro from here):
I had the pin welded back into place after it fell off. It was possible to weld it through the starter hole, although not easy. The pin was tacked to a flat metal bar which we bent so that I could hold the pin in place from the top of the engine bay whilst my welder friend welded it back on to the flywheel.
i had this done on my 20v rr quatt it stood for 3yrs b4 bless him mr p payne found problem as it had a chippd mtm chip in it so it was not bringing up the flywheel sensor code up so no one checked it so a few mechanics rippd put the alarm then seperate immobiliser then half of dash saying its got elect prob then ecu faulty as it had no spark etc until the late mr p took out the starter & found prob but i got another flywheel ready for him to change its a dog of a job as mine had snapped in the flywheel & not fallen out so it was much much harder just to do it in situ through the starter hole as it had to be drilled out etc so can be done so good luck sir
After seeing this I think I will give mine a squirt with the TIG before I send it off for balancing in a few weeks.
I have been advocating pre-emptive additional welding on the G4 Timing pin for some years now, after several documented stories of the pin coming off the stock DMFW with time.
Note Paul N's recommendation about unplugging the battery, the ECU and ABS computer before firing up the welder.
..As my flywheel has been lightened I was able to take some more material off the new pin as it didn't need to be as big....
... and I need to make a better job of centreing it!
Also need to look at getting a smaller TIG torch to make access easier as there is virtually none at the moment using the torch I have.
1. Not following your lightened flywheel = okay to have a smaller pin. It is a pin that is too small that is causing you grief now.
2. In the examples I think I gave, the bigger pin was drilled so that if fit over the round pin (which one assumes was in the correct location).
3. Doesn't anybody remember arc-welding rods? They are long and only about 1/8" diameter. Very easy to get in there with welding rods. Wire-feed welders aren't the solution to all problems.
Just saying...
