1. If you look closely at the 3rd picture you cn see that the inside face of the flywheel has been machine away, if I'd kept the pin the original size, most of it would be hanging in fresh air. I've shortened it so it's flush with the step.
2. There is just enough of a stump left on my old pin that it can be used to centre the new one, I just hadn't done it correctly when I took the picture.
3. I'm using a TIG welder not a wire feed ( MIG ) welder. I could probably do it with the torch I have, just trying to make a difficult job a little easier
