I get my car back in the morning, the cause of my oil leak was as suspected, the cam cover gasket had been blown out behind the cam wheel probably caused by boost pressure leaking past the foot valve in the breather system.
Miraculously the belt was dry so not too bad really. Although the old valve seems to be working a new one has been fitted anyway. That and a new cam cover gasket which has been rubbing on the back of the cam wheel.. I'm not sure that these plastic valves are really up to the rigours of 2 Bar of boost
I know a bunch of you are running the catch tank type breather system and I'm starting to understand why and my thoughts are going that way but I'd really like to keep the sealed system if I can. So does anyone know of a better valve that can be fitted (we thought about using 2 in series, for example) or a way to vent pressure in the cam cover, should it arise, without compromising the integrity of the PCV system? Could I fit, say, a 1 Bar blow off valve in the cover?
I really dont want to blow that gasket out again.
I'm even thinking of trying to make a valve in alloy that would seal better and be more robust than the stock plastic one. I'm going to pul the old one apart and have a look anyway.
