Audi RS2 timing or belt question
Ok doing that comparison I can clearly see that the hall window is offset. Here is the key and the mark on the outer ring ligned up and the difference seems to be the hall window. A comparison of the pictures of the back side should still be done to get it 100% but it shows really good doing it this way.
Yeah I understood that
Got it tightened as it should but the bolt on the crank I can't get tightened to specs with my tools
I got it to 200Nm and then did another 90-100 degrees but I got no chance of getting the last 80 degrees on it. I broke two extensions now... I'm not even sure I could manage to do the last 80 if I got bigger tools as I'm already using a 170cm arm to put force on it and hanging on the end with 90-100kg pressure while trying to "shake it" makes the tools I use crack.
Not many people get the full 180 on them. If its over 90 and in with thread lock it should be ok
Sent from my GT-N7105 using Tapatalk 4Comment
This is what I said the difference would be. And if I can figure out how to lay a protractor over the diagram, we will be able to see how much (I presume it will be 10 degrees).Ok doing that comparison I can clearly see that the hall window is offset. Here is the key and the mark on the outer ring ligned up and the difference seems to be the hall window. A comparison of the pictures of the back side should still be done to get it 100% but it shows really good doing it this way.
Back shortly with the "red-lined" diagram/photo twoqu mentioned (sorry I am just up (8:05 AM here).RS2'd 93 UrS4 5 spd sedan
Yeah. I'm so in doubt if it's enough or what. I was using 1/2 now as that's the biggest I got but I did feel that it was close to either breaking the extension, the wrench or the 27mm that was used. What sucks now is that it's pooring down, my GF took the allroad so I'm left with the motorcycle to drive a hour to fetch 3/4 tools
Turning out that I have alot of questions
I'm not an educated mechanics so I hope you can bear with it..
Aligned up the crank as it should be at TDC sylinder 1 (the one to the front) and I did check down the plughole that it was actually at top as I had the mark in at the crank. This is then how it looks like underneath the cam cover. When I put on the cam cover it's also aligned a half tooth out "like it should". The marks on the cam do not align up.
If I then do align the cam's to the mark inside the cam cover I get far out on the crank and the mark is a tooth out comparing to the edge of the top like shown in the pictures below.
Far out on the cam pulley..
Look how far out the crank mark is.
Now.. I'm skeptic to this not aligning up at all for one reason. My car has obviously had the wrong pulley on the crank so I'm wondering if the ones putting on the wrong pulley also put the cam at the wrong place on the chain to compensate for using a wrong pulley. Since we found out that the mark on the pulley and the key was at the same place on the different pulleys in theory everything should be mechanically correct as it was before but I can't help noticing how everything doesn't align as it should.Comment
It is over 90 and I applied thread lock to it. As I'm seeing now there is actually 1/2 torque wrenches that goes to 350Nm and one of the extensions I used was the "heavy duty" (don't know the English word for it but the one that should be used for thick walled version of 1/2) so it should be at least as strong. Hmm in doubt if i should bother getting 3/4 to do 180 degrees now..Comment
It is different.
Here is the AAN one again (RS2 below it)
Sorry, I rotated the original RS2 105B photo but not quite perfectly. Still, you can see the difference in the shutter opening alignments.
I think the issue is this 10 degree difference. As far as I am aware the cams would be aligned only if the TDC mark on the pulley was at the ABY not the RS2 position. I will have to look more closely but unless Audi/Porsche took the time to remark the inside of the pulley then its not going to match when installed at the RS2 position. Don't forget that as the inlet cam is identical to the ABY (I believe) then the only way to get the published difference in the timing is to physically move it. Once you move it the marks don't line up! All of this could have been avoided by putting the marks in the right places on the pulley.
See what others think whilst I check the marks!Comment
The two marks seems to be in the same place relative to the amount of teeth spacing on both pullys. One indicates TDC and is at the back of the front TDC mark the other is presuamably to indicate TDC against the rear of the cylinder looking from behind unless I am mistaken. So they would only align if it was set to ABY timing not RS2.Comment
1976 RD250E / 350LC cafe racerComment
