Recently bought a RS2 -94 that had a problem with not running clean when the turbo pressure comes. The 1. gear is pretty good but from 2. and up it has hesitation and gives a weird sound while revving up. I have cleaned the MAF, now recently changed from AAN/ABY cam pulley to ADU cam pulley with the hall window at the right spot and I've checked the intake for leaks (just with 0.1bar pressure or so). I'm open to suggestions to what to do. I got vagcom and I can log more or different if that can reveal something.
I tried to log the problem revving up on 3. and 4. gear but I don't think I got the error logged. The .CSV file is here tho if anyone want to have a look at it.
This is what I get as a readout when I check for errors with vagcom.
Saturday,17,August,2013,09:37:32:08464
VCDS Version: Release 11.11.6 (x64)
Address 01: Engine Labels: None
Control Module Part Number: 8A0 907 551 B
Component and/or Version: 2,2l R5 MOTR.RHV RS2D03
Software Coding: PMC 4
Work Shop Code:
VCID: 264348F7C2C61D287A7
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Readiness: N/A
The sounds that sound like it's a bumpy road are the engine hesitating and not revving as it should. It was hard to capture it on video but you feel it really good when driving.
Just in case the youtube videos in the forum don't work the links are here. Video 1 link - Video 2 link
Work Shop Code:
1 Fault Found:
00-00 - -
Readiness: N/A
I need to make a better tool to do a safe test at 1 bar. If I'm not wrong the bung will have approx 200 kg of force on it at 1 bar and I doubt that my tool will survive that. At least I don't want to try and have it shooting all over the place. Will see if I can come up with something. Is it indication of a air leak?
