Yeah it was earth for the coils I meant. Will have a look there.
I think so. I oriented it so that the pressure comes onto the "spring" and get's released on the side of it.. I found the picture below on google now just to demonstrate the way it was mounted (don't look at the rest there). Will it even give a difference in performance mounted the wrong way?
Well I do have a megasquirt kit lying around that I soldered up last winter. I could actually hook that up just to log values (not controlling outputs). Still missing sensors tho but there is a MAP sensor built in on the board if I recall correctly so then the turbo pressure could be logged atleast. Also have a broad band lambda sond with two outputs that I could put in. Will def. look into this in my next period off work as it would be cool to have accurate logs for later also.
The car will not be used anymore until I can find out what this is. I also got a weird sound in it after doing the pulley change and it sounds like it's coming from the crank pulley. Prolly me forgetting to adjust that hall sensor I guess so will have a look at that tonight if my GF let's me out there again
Hehe I had that thing before but I got motorcycles to cure that disease as it's a lot cheaper to get a motorcycle to perform
This will be a car built back to how it was delivered from Audi and then used on sunny days when not resting in the garage.
