The firetrap may be quite far up the PCV pipe (between the big T-piece from the block & back of the head), i had to push a wire with a hook up there and fish it out. Its a flame catcher, Audi found a reason to put one in there so I'd say worth replacing if its missing.
Have you checked for ignition problems? If the coils or POS are giving up, resulting in a weak spark, it would give you running problems as you come on boost, more severe the more boost pressure your making. Saw that on my old avant before i replaced the coil packs.
It was first the cam pulley that I found when originally searching for a oil leak and now this air leak. After I got the air leaks away I will go on with ignition and/or MAF I think. Really tempting to go for the 1.8 turbo coils and swap them now just to see since I'm going offshore for work in a little under a week and it would be fun to find out of this problem before I head off :X
