Gtx35 on a 2.2
  • mac2226
    • Jun 2008
    • 1289
    I would go gtx3071 and a tial housing for street use, but if your after 600+ then gt3582 tial should get that power with engine mods I would of thought
      Originally posted by Rocco
      why did you buy the huge Comp Jamo?
      The comp was smaller than a GT35R it was the same spec as a 3576r plus it was on a 2.5 litre so 500 earlier spool aka it was like having a 3076r on a 2.2
      Anymore questions?
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #33
        Anymore questions?
        Thought it was for 650hp ...
          The last turbo KRB dyno'd using that turbo did 680 bhp, mine wont do that unless you fitter the larger hotside it will top out around 600 IIRC
          Anyhow new owner has the car now I am now looking at starting over with the RS4
          • martinws
            • Oct 2008
            • 917
            I say buy it and ill buy your GTX3071 from you.
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #36
              Damn should have spoken sooner! Haha
              • PRY4SNO
                • 767
                Anymore questions?
                Yes, my question is what Comp turbo did you get?
                2013 Touareg TDI /// #farmenwagen
                  A shiney one
                  • jsws3
                    • Apr 2012
                    • 1174
                    So are the comp turbo better made the garret turbos and if so what one would be good for 600hp?
                    And a link from where to buy would be usefull.
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      #40
                      but buy throught KRB trading in Norway
                      • prj
                        • Mar 2010
                        • 6308
                        Stay the hell away.
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          #42
                          Originally posted by prj
                          Stay the hell away.
                          have you ever mapped one D?
                          • PRY4SNO
                            • 767
                            Stay the hell away.
                            Customer service, or reliability?
                            • rynaqui
                              • Mar 2012
                              • 2752
                              • Country: Malta
                              #44
                              I think in general for turbos, most commonly and reliably used have been KKK, Garrett and Holset? Seen some pretty scary stuff with other turbo makes on here!
                              1996 S2 ABY Silver
                              • urs4guy
                                • Dec 2007
                                • 192
                                Count me in as a happy Comp Turbo owner. I have a CT43-6768 BR billet compressor, triple ceramic ball bearing turbo that paired with my 2.5 stroker provide all kinds of excitement. The last dyno run came in at 755hp at the wheels. At 4000 rpm its pulling about 228 ft/lbs of torque, at 4500 its 352 ft/lbs and at 5000 its 668 ft/lbs. Yes, all hell is breaking loose. It now has a billet compressor and I have not dynoed it with the lighter/slightly bigger blower. We're also adding all kinds of stiffening and a billet crank so stay tuned.
                                Hap, wit dakine plans not from Evahboost, Maguire
