oil catch tank
  • oil catch tank
    Does anyone use an oil catch tank? Is ther any advantage of using these?
    Gabor
    96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
    I'm using one. Advantage is less oil(fumes) going into the engine. Some of the 2.5 TDI's have a oil separator(catch tank) as std.
    A disadvantage in cooler climates is that there is more condensation in these tanks/pipes/hoses and you can blocked lines because of "yellow slush" freezing inside.
    Cheers,
    Roger
      The main advantage is that you don't have to worry about that little stop valve breaking and blowing your cam cover gasket out...
        Roger have you got anymore details of theses catch tanks out of the tdi's?
          Would also like to know about factory fitted tanks on the TDis ! Palease
          Paul
            Page from family album:
              I have a question: why returning the filtered air back into the turbo, and not just let it go up in the air?
              Audi Quattro WR
                Because for the MOT your not allowed to vent the fumes to atmosphere and it is ment to help performance by having it connected to a vacuum.
                  Any idea on price for the tank?
                    Im getting my copy of the family album later on from my mate at main dealer.... he is also forwarding me all the updates of pricing so will be able to look stuff up at long last, seems i lost my last CD
                    Ant
                    2011 Kawasaki Z1000
                      There is absolutely no performance help as the breather air is already one time burnt!
                      Factory catch tank.. didn't know about those.
                        what is MOT?
                        I have an oil catch tank on, but with no air return. Does this mean i get less air into the turbo or not? The air from the oil catch gets otherwise back in the air line just before the turbo, so it is bypassing the LMM. Is this bad?
                        Audi Quattro WR
                          MOT is a test to check the roadworthyness of vehicles every 12 months once they are 3 years old or more.
                          With the performance bit I have got the book to hand to quote it so wont put anything on here about it just yet
