7A hesitation/flat spot
  • goodall
    • Jul 2008
    • 810
    Having got my 90 20v on the road over the weekend, I've started to have problems. Between 2800-3000rpm and 4400-4600rpm the engine dies out and slowly builds until it pulls again strong. I've searched and found it may be the knock sensors and have replaced these with two from a AAN engine and the flat spots are still there... HT leads and plugs seem ok and wouldent expect them to cause such rpm exact conditions everytime
  • spink
    • 4382
    Reading the codes will quite likely give you the problem
    • goodall
      • Jul 2008
      • 810
      Can't find my vagcom... So randomly replacing things
      • spink
        • 4382
        Pissing in the wind mate.btdt too many times
        • goodall
          • Jul 2008
          • 810
          Looking like I need pull the house apart then. Or get an led....
          • Jamin
            • Feb 2011
            • 83
            • Home: England
            Have you reset the ECU?
            1992 80 quattro 1.8T
              Just make a test light, takes about 5 minutes, all you need is an LED and some wire.
              Knock sensors in my experience on the 7A basically make the car feel really flat and lazy to rev, but still smooth. As James says need to pull the codes could be one of many things
              • Mikes2
                • 1704
                7A uses different knock sensors from the AAN.
                They're not compatible
                Mike
                http://www.s2-audi.co.uk
                • goodall
                  • Jul 2008
                  • 810
                  Found my cable, plugged it in read the ECU no fault codes. So took the car for a drive, nade her do the bd behaviour, didn't turn the motor off ran vagcom again still no faults. I'm at a loss
                  I know the knock sensors are different but read a number posts where others had success...
                  • PRY4SNO
                    • 767
                    Try the CPS.
                    2013 Touareg TDI /// #farmenwagen
                    • goodall
                      • Jul 2008
                      • 810
                      Will try my spare one tomorrow
                      As a double check did the blink codes got a 4444 so no measured faults
                        Hmmm, the TPS can sometimes be a PITA and throw no codes. Yours will be the later one I guess?
                        They are much easier to get hold of luckily, early ones are really rare in good working condition
                        • goodall
                          • Jul 2008
                          • 810
                          I have a spare to borrow parts from, so will try the throttle pot too, but if I don't slove this there's an AAN sitting idle could go in, doubt the 3.6 V8 be a better idea
                            Does the 7A have an IAT sensor? Similar symptoms on the ur when this is bust or has a bad connection, don't know if this would throw a code or not though..
                              Originally posted by PRY4SNO
                              Try the CPS.
                              Crown Prosecution Service?
