Right.
I have just taken out the cylinder head to find the coil nearest the windscreen totally split half way down,
Moreover – the plug 2nd nearest the front had broken – the small nipple on the top of the spark plug had got wedged down the side of the side and had to be removed with a pair of chop sticks!!
Ok, all put back together and there is MASSIVE difference in performance!!
But I hate to say it, the problem is still there.. Is this due to the massive split in the black pipe leading down from the coil????
There is a huge well of oil in the bottom of the pipe where it was split..
Pictures may explain better than words.
(Or clean your old one) then you'll get reliable boost control.
PLEASEEEEEEEEE! it already feels so much beeter with the new plugs. One was bloody broken!!!!!
