Black pipe to coil split (picture attached!)
  • Honahon
    • 90
    Right.
    I have just taken out the cylinder head to find the coil nearest the windscreen totally split half way down,
    Moreover – the plug 2nd nearest the front had broken – the small nipple on the top of the spark plug had got wedged down the side of the side and had to be removed with a pair of chop sticks!!
    Ok, all put back together and there is MASSIVE difference in performance!!
    But I hate to say it, the problem is still there.. Is this due to the massive split in the black pipe leading down from the coil????
    There is a huge well of oil in the bottom of the pipe where it was split..
    Pictures may explain better than words.
    SOLD.. :(
    But now proud owner of Porsche Boxster S.. :fire:
  • audiman
    • 4827
    Thats possibly your problem, these are what insulate the spark from going to the cylinder head instead of through the plug. The reason they are covered in oil is due to the Rocker cover gasket leaking. Replace the rocker cover gasket (it comes as 4 pieces) and then clean out the plug recesses as best as you can, using a rag on the end of a screwdriver. Replace all the coil ends. These are the cheap bits!!
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • Honahon
      • 90
      number 2
      SOLD.. :(
      • Honahon
        • 90
        number 3
        SOLD.. :(
        • Honahon
          • 90
          And That's Where All My Bloddy Oil Has Been Going!!!!!!!!
          SOLD.. :(
          • audiman
            • 4827
            LMAO. Maybe, make sure you give the thread a good clean before fitting new plugs. Also make sure that you torque then down. If you dnt have access to a torque wrench then just recheck them in a months time or so. They have a habit of working loose.
            Audi UR Quattro
            • Honahon
              • 90
              ****, I have just put 5 new plugs in !!
              SOLD.. :(
              • audiman
                • 4827
                Ah, dont worry too much, it wont matter. Just recheck them every couple of months or so.
                Audi UR Quattro
                • Honahon
                  • 90
                  The burning question.
                  Where do i get the parts from I need? VGA parts?
                  SOLD.. :(
                  • Honahon
                    • 90
                    Thanks for your help Tom.
                    SOLD.. :(
                    • audiman
                      • 4827
                      VAG parts or Audi for the coil pack extension things, and GSF or VAG parts for the gasket kit. Best bet is to buy all of it from VAG parts IMHO.
                      Audi UR Quattro
                      • Honahon
                        • 90
                        is changing the rocker cover gasket a big job? can I do it..
                        SOLD.. :(
                          Honahon, this was the same on my car at the first RR meet that Greg organised, the oil leak was causing a big missfire. we managed to improve things by cleaning out all the oil then Martinjs lent me a spare plug lead to use instead of my bad one.
                          Replace the Gasket and that bad plug cap. Phone Martin at VAGparts.
                          You still have to fit a new WGFV though don't you (Or clean your old one) then you'll get reliable boost control.
                          • Honahon
                            • 90
                            I have a WGFV downstairs waiting to be fitted!!! I REALLY CANT WAIT... looks like i'm gnoa get it all sorted.. PLEASEEEEEEEEE! it already feels so much beeter with the new plugs. One was bloody broken!!!!!
                            SOLD.. :(
                            • Honahon
                              • 90
                              Numero 4 - and that was a good pipe -
                              All the back pipes and broken in one way or another. Split or the rubber hope at the bottom has broken off
                              SOLD.. :(
