I can pretty well guarantee that you did not measure fuel pressure at the rail at WOT and full boost. Pump curves are a compromise combination of flow and pressure. Pumps can produce lots of pressure but very little flow or lots of flow but very little pressure. I know, based on work done by Sean D. (quattro20V), that the OE 091G fuel pump will produce around 86 psig. However, I also know from my RS2'd UrS4 that the flow capacity of the 091G is starting to be (or is) maxxed out at that pressure.
(86 psig (5.93 Bar) is critical to an RS2'd AAN because 4 bar = 58 psig and 28 psig boost (1.93 Bar) = the pump needs to supply at least 86 psig (5.93 Bar) and all the flow required by the injectors as the ECU keeps them open on a duty cycle that is likely approaching 90% at WOT).
Just for reference, an exaggerated fuel pump curve (the black line). Unless you are artificially manipulating the "boost" pressure on the FPR at idle, I think you are measuring pressure at a very low flow. I expect you will tell us something new in reply.
I mounted my gauge on the hose from fuelrail to inlet on FPR..
