Urs4 running lean . Lambda, MAF, pressurer regulator?
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    #106
    I think you should do this more simple,fill with what you have on the car.
    Turbo.....
    Wastegate/spring......
    downpipe/exhaust......
    fuel pressure on boost at high rpm.......
    Software you are using........
    This should be solved hardware first and after that sw.
    And symptoms again(excuse me but to many pages)
      Have you inspected the bottom of the car? Perhaps the return line has been crushed, on a speed bump maybe?
      • Val
        • Apr 2008
        • 630
        • Country: Latvia
        #108
        Originally posted by prj
        Check your timing, might be one tooth out.
        Timing best is perfectly aligned. So as early hall sender is perfectly aligned.
        Belt was changed previous summer.
        What's next?
        5vtq gte
        • Ugemi
          • Feb 2010
          • 24
          I allready forgat. Does you boost gauge(the original in the car) show the boost as well(so does the ecu see be boost)? If not, check the boosthouse to ecu map.
          • Val
            • Apr 2008
            • 630
            • Country: Latvia
            #110
            No, boost is visible in analogue boost gauge. Don't have boardcomputer connected yet.
            5vtq gte
            • Isaksa
              • Oct 2013
              • 64
              • Country: Norway
              #111
              Yes Iv'e thought of that also yesterday.. Wold have been so happy If that was my problem. But it is showing boost.. I have 3bar map sensor btw..
              But i haven't checked timing yet since it is running "ok" with normal driving. Mabye worth a try.
              Iv'e pretty much given up my car..
              I have a 13month year ord kid that also need time with me, and my wife ofcurse :-)
              My next step seems to be an expencive one, If i have to ordet standalone ecu
              Sent from my GT-I9300 using Tapatalk
              • Ugemi
                • Feb 2010
                • 24
                I hear you. I have 3 y and 5 months old girls. Then again, I dont think the ecu swap changes anything, there is a problem somewhere and you need to find it.
                I´d check the boosthouse to ecu one more time. Even a small leak could cause it.
                Do you have any chance on changing injectors? How old are they?
                • Val
                  • Apr 2008
                  • 630
                  • Country: Latvia
                  #113
                  NO IT IS NOT LOOSE. It is a myth. This problem does not exist.
                  You were right. No changes.
                  Does VCDS see MAP in the 551AA Motronic ecu?
                  5vtq gte
                  • Ugemi
                    • Feb 2010
                    • 24
                    No.
                    • Isaksa
                      • Oct 2013
                      • 64
                      • Country: Norway
                      #115
                      Turbo.....
                      d0ownpipe/exhaust......
                      -Custom preciscion turbo . AR60 rs2 manifoil
                      -3" downpipe, and simons 3" exhaust (no cat)
                      -Race ported cylinder head, dobble valve springs and titan retainers.
                      -Bosch 0280 155968 injectors.
                      -4.8bar fuelpressure. Rises with 1:1 ratio? Have tested witn Begi FPR and fuelpressure did rise way to fast with this one.
                      -Bosch 044pump 1.2liters in 15sec
                      Did find some loose nuts. This canot cause wideband sensor to get wrong values? if i had leakage?
                      MAF :
                      Test mounted boost/afr gauge's
                      Havet been in the garage for one week now, after i saw this
                      • Isaksa
                        • Oct 2013
                        • 64
                        • Country: Norway
                        #116
                        I do not know the age of my injectors. Previous owner have changed them i think.
                        Will perform a new leaktest when i have the time. Last time iv'e checked , i did not manage to build up over 0.6bar etc. .Sounded like air went out turbo oil return? hmm
                        • Isaksa
                          • Oct 2013
                          • 64
                          • Country: Norway
                          #117
                          Pressure test is easiest to do with a car air ventil(sorry my bad english, I mean the kind of, that you have in you tires http://www.tarvikkeet.fi/img/kuvat_pienet/444.jpg ) and a suitable sice can of some sort, that you can connect to you turbo inlet http://razur.pp.fi/S4/vuototesteri.jpg . Then just add pressure with a air compressor for 2 bar, or so http://urly.fi/b3E.
                          Hi!
                          I have made my own tool. And when testing, i did not archieve more than 0.5bar. I susspect that all the air is going out turbo oil retur line. Is that possible?
                          • Ugemi
                            • Feb 2010
                            • 24
                            No it is not. If the air goes to the oil line, then the oil would also come the other way. That would show as a lot of blue smoke in you rear view mirror.
                            • Isaksa
                              • Oct 2013
                              • 64
                              • Country: Norway
                              #119
                              Ok
                              My engine is not burning oil. And haven't needed to refill
                              I may have some problems on the intake side on turbo then, after MAF. I can hear leekage, but it sound "intern" and not going out to open air.
                              • Ugemi
                                • Feb 2010
                                • 24
                                Spray bottle and soap water. You should see bubbles
