I found a leak today. There was leakage of a seal in WG, but this is probably not my problem with running lean..
Iv'e noticed this problem on my way home today..
If i push the throttle, and aim at 2000rpm and then keep steady, it start to bounce 500rpm up, and then down again. It's the same at 3000rpm, Afr gauge shows fuelcut when rpm goes down.
Can this be my problem?
I have added a video:
No vacuum or pressure inside..
