MAF and air filter?
  • Rikki Kitto
    • Feb 2010
    • 6276
    MAF and air filter?
    Do ya reckon this might be causing problems just thought I'd check it as it's the only thing I haven't, thought it was done by the engine man when he put my new engine in, apparently not
  • Bowie69
    • Nov 2013
    • 2675
    Why's the end of the filter been cut off.....?
      Okay the MAF screen could be some kind of mistake/oversight but trimming the air filter gasket to make it fix the airbox is complete BS. Somebody needs a slap upside the haid.
        • 4754
        Anything that looks like the maf and the filter should ring ALARM BELLS It's just not cricket old boy! Underhanded bowling there if you get my meaning.
        Easy enough to sort out though.
        • Rikki Kitto
          • Feb 2010
          • 6276
          To be fair he said he never looked in the air box so had no idea about the filter and state of MAF, I put a new filter in tonight and it fit fine so no clue as to why this would be done. Got a spare MAF in the shed so will fit that n see how it is. Had the tyres screeching round the local roundabouts tonight an seems to rev to 7 thou without hiccups so who knows😊
            MAF screen on my 3B was exactly like that when I got it.
            • Rikki Kitto
              • Feb 2010
              • 6276
              Any ideas what can cause this sort if thing and can it be repaired
              • andy10v
                • 5996
                Just whip out the wire lock and remove the damaged screen.
                Sold ABY-stock
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  Then just leave it out?
                    Not a good idea if you want to a) protect the hot-wire in the MAF and b) maintain nice straight flow into the MAF so the portion of the flow that the hot-wire samples is representative of the entire flow.
                    Alternatives include the mesh style that the RS2 MAF uses or a 3D honeycomb metal mesh.
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Good point, now where to get new mesh?
                        Or honey comb:
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          Nice, just remembered I bought a brand new old stock original maf of fleabay ages ago, buried in the shed pulled it out seems to work finesorted not bad for £65
                          • Cottis
                            • Feb 2011
                            • 1448
                            £65? Bargain. You got anymore hidden away you wanna sell ha ha? Mine was replaced a few years ago, so hoping it will be good for a while but dreading it going pop. Don't think they exist anymore. Can you send them back to Bosch for reworking?
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              No idea but once I get a new mesh the old one will be a good spare worked fine even like that
