My cold air intake
Moving the MAF anybody did this?
-------------Attached FilesComment
Yeah but it kinda sucks using money for remap, BOVOriginally posted by RIXhej jonas
trottlebody is gasspjæld in danish,
if you move it,and get a real blow off,you could just throw the intake hose away,and bolt the filter direktly on to the turbo,i will also safe up for the HKS filter,and bolt it on to the turbo.
Regards
RIX
not money i quite have, but perhaps i will try to save up some money for this.
/Jonas R.Comment
Like the heatshield, but i guess your MAF is still in the same place as normal right? So i guess you have no problems running with the MAF like that?Originally posted by SøernS2-------------
/Jonas R.Comment
his pictures are old,the last ti´me i saw it he had a 90 bend down,as fare as i know he has put it on the pipe on the right.Originally posted by Jonas_RLike the heatshield, but i guess your MAF is still in the same place as normal right? So i guess you have no problems running with the MAF like that?
/Jonas R.
Regards
RIXComment
These are old pix.
I have the MAF 2 feet from the trottleboby on the pressure side.
Ill post new pix soon...
Søren S2Comment
Maf to Hot side
Looking for Info on this topic and where possible a picture (Soren S2)Originally posted by SøernS2These are old pix.
Søren S2
In an Ideal world I want to bolt a filter directly onto the Turbo so
1. Filter faces in the right direction
2. A larger filter can be accomodated
3. Create space fore HID kits in the future
To achieve this I think I will need to move the MAF to the hot side but need a picture to know where best, I do understand that a re-map will be needed but currently I am running standard and need a power map anyway.
.91 S2 3B in Pearl, Miltek, De-Cat pipes, Short Shifter, 996 Monoblocks + 323 A8 Discs, Whiteline R-ARB:MRC Generic 3B Chips
.Comment
Thanks Soren, but still cant see where you have positioned the MAF91 S2 3B in Pearl, Miltek, De-Cat pipes, Short Shifter, 996 Monoblocks + 323 A8 Discs, Whiteline R-ARB:MRC Generic 3B Chips
.Comment
Mine is hereAttached FilesComment
My setup is standard at the moment and you look fairly moded
I dont think that would be the best position for me at this time, but thanks for the pic.
.Comment
