Nice one
Fuel Tank Breather System - Coupe
99 2.8 final edition Cabriolet -
Seems to be ok now Greg
The spigot was actually soldered into the tank with soft solder which had cracked part ofthe way round so you could move it a few mm with your fingers. The solder was easy to scrape off with a screwdriver and I giot it really clean with Scotchbrite Red and carb cleaner, hopefully the Quick-Steel will hold it.Comment
