rs2 timing belt
  • AndyRS2
    • 128
    I spoke to Audi Tradition, the RS2 Cambelt with 150 teeths, will be for sale soon.
    Audi 80 1.6TD Dailydriver
    Audi 90 20V Quattro Sport
    Audi S2 Coupe ABY
    Audi S2 Avant
    Audi RS2 Avant Nogaro Blue
    Audi RS2 Saloon Nogaro Blue
    • diesel des
      • 3896
      #32
      Andy, how soon is soon? I was thinking of modifying the idler so it is bigger and would allow me to use the 151 tooth belt. I want to put the engine in next weekend....
      • diesel des
        • 3896
        #33
        After some testing I reckon increasing the od of the 3b oil pump idler I'm using from 74.8mm to 81 will get the tension I want with the water pump 2/3 of the way along its adjustment. So I'm getting a steel sleeve made up 75mm I'd 81mm od 28mm wide and pressing it onto the idler with bearing fit compound and tacking it on there in a few places.
        Sent from my GT-N7105 using Tapatalk
        • rxl
          • 1913
          Anyway the belt on my rs2 with 26 tothed water pump
          • diesel des
            • 3896
            #35
            Rxl that isn't the correct belt for a rs2. It has 151 teeth and the correct belt has 150. Obviously it will work but your Tensioner must be almost fully tight.
            My problem is that I have a stroker engine with 3b s2 oil and water pumps so my weird setup needs something shorter than the 151 tooth belt or a larger idler.
            Cheers des
            • rxl
              • 1913
              Well I know that the belt is the wrong one. But it was on the car and worked. Do you have some pictures or a thread on your stroker project?
              • diesel des
                • 3896
                #37
                I haven't started a thread yet but I have taken many pictures. Hopefully will be running in the next few weeks. I'm going for torque and low to mid range power, not big bhp. I'm going to try a efr 6758.
                • rxl
                  • 1913
                  Make one... Want to see some custom work.. Have seen some for a time
                  • diesel des
                    • 3896
                    #39
                    Ok started...
                    • huksa
                      • Jan 2012
                      • 121
                      • Country: South Korea
                      #40
                      As of Sep. 12, 2014, the RS2 timing belt 034109119C is available at Audi Tradition.
                      • diesel des
                        • 3896
                        #41
                        I wonder what the cost is?
                        • rxl
                          • 1913
                          58,91 Euro plus postage.
                          • huksa
                            • Jan 2012
                            • 121
                            #43
                            EUR 49.50 for those who live outside Europe
                            • rxl
                              • 1913
                              And the shipping is like 15euro?
                              • huksa
                                • Jan 2012
                                • 121
                                #45
                                Well, in fact,
                                I bought the timing belt and water pump together. And Audi Tradition charges EUR 24.00 for both parts to South Korea.
                                I am very satisfied.
