rs2 timing belt
    Hopefully, it will all be academic soon, when Hank makes it easier for all of us to upgrade to the 07K engine.
    It seems way better in lots of ways.
    • pasbogdan
      • Sep 2009
      • 1160
      • Country: Romania
      The SKF they sell for adu is 29 teeth
      • rxl
        • 1913
        Its the wrong one...
          I have not seen enough used blocks to have a strong opinion, but FWIW I have noticed that 3B blocks seem to wear less for similar mileage than later ABY & AAN blocks so maybe they went cheaper on the material?
          • irishs2
            • Apr 2009
            • 2455
            Distributor problems causing a more rigorous service schedule.
            Eric
            95 S2 Avant under rebuild.
              • pasbogdan
                • Sep 2009
                • 1160
                • Country: Romania
                #22
                • veneto rs2
                  • Jun 2006
                  • 1022
                  • Country: Veneto
                  #23
                  Originally posted by pasbogdan
                  Ok.The rear of the pump is the same?
                  Yes
                  http://www.audisportclub.com/
                  http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
                  • sailaz
                    • Oct 2009
                    • 647
                    • Country: United Nations
                    #24
                    just wondering how many teeth has BGA CP18558 because in some catalogs it is given as analog for original VAG 034121004B
                    • fridtjov-audirs2
                      • Jun 2005
                      • 131
                      • Country: Norway
                      #25
                      How deliver timing belt for RS2 now?
                      • rxl
                        • 1913
                        Audi Traditions have it on stock.. i payed 65euros incl. posting
                        • tommi78
                          • Jul 2008
                          • 1
                          Adu timing belt
                          Hello
                          Where I can buy new belt for my RS2(034 109 119 C)? It seems that no body is selling 150 teeth belt any more.
                          • rxl
                            • 1913
                            Originally posted by tommi78
                            Hello
                            true got the last belt so its seems...
                            anyway somebody has bought a few timing belts and is selling them if your willing to pay the price http://allegro.pl/pasek-rozrzadu-aud...424300761.html
                              Just use a normal ABY/AAN belt. The length of the belt makes no difference as long as it is tensioned correctly. The number of teeth on the crank sprocket and cam wheel are what matters
                              • diesel des
                                • 3896
                                #30
                                Guys do any of the aftermarket companies make a proper rs2 belt eg 19 mm wide 150 teeth 034 109 119 C? Or has anyone talked to a drive belt company to get these made. Seem to have 8mm pitch. I need a proper adu rs2 150 tooth belt for my stroker build. I couldn't find these on audi tradition. Help! Cheers des
