Occasional overboost cutout?
  • porkkis
    • 1994
    That's right. If you managed to find out that, you don't need to replace it. Just clean it well.
      Hmm, sucking on it gave me a nasty taste in the mouth I can tell you
      • frjd
        • Jul 2004
        • 26
        Hi
        Did you find the solution to this problem, I have expirenced the same problem two times.
        First time it cutout every time I gave full gas, (guess overboost) there was
        no cutout with just almost full gas. It did this several times on this drive, but after
        a short stop (engine turned off for mayby 5 minutes) nothing happend for many
        month, then 14 days ago, it did it again, exact same problem, and again it went
        away after I stoped the engine. - And nothing since. What Im afraid is what happen
        if this happen in the middle of a overtaking.
        Now mayby my description can help solve the problem, I also would like it fixed...
        Originally posted by newsh
        Every now and then, maybe once a week or so, ( yesterday I drove about 500 miles it happened 3 times), I get a cutout at full throttle.
        Because its so rare I always miss what rpm and boost pressure, I always back off and or change up when it happens. I think yesterday I saw the boost gauge hit 30lb once just after it did the lurch,(car is mapped for about 25-27lbs, I think, Mihnea?) usually happens in a high gear and I think usually at around 3.5 - 4k rpms. If you floor it again immediately after, it is fine, so its not going into limp mode.
        Any ideas guys?
        • frjd
          • Jul 2004
          • 26
          I did it again, this time I cut the engine, and started again, and the problem went away.
          • Dr H
            • 1175
            Sounds like mine - have you checked the fault codes? I'm getting 2224.
            • frjd
              • Jul 2004
              • 26
              Sorry, I do not have access to a vagcom or other tool to readout errors.
              • Dr H
                • 1175
                All you need is a 12v LED and a short piece of wire to read the codes.
                See www.s2central.com under technical > engine and tuning > Motronic ecu > diagnostics > blink code pages
                HTH
                • frjd
                  • Jul 2004
                  • 26
                  Two times more, again "rebooting" (engine off/on) the car eliminate the problem.
                  • frjd
                    • Jul 2004
                    • 26
                    The failure happend 12/7 again I turned off the engine, and again it run fine.
                    It really seems to me to be a computer error, how else can the error be gone by restarting the engine.
                    Today I got my vag-com. I read out this:
                    00561 - Mixture Adaptation 13-00 - Adaptation Limit (Mul) Not Reached
                    00513 - Engine Speed Sensor (G28) 03-00 - No Signal
                    I then reset the error log.
                    This afternoon the error happend again. Again engine off eliminated the problem, however this time the error happend again within few minutes.
                    I then read out the errorcodes again, not I also got a 544, I thing it is strange that
                    this was not in the log from the previously errors since last year.
                    00544 - Maximum Boost Pressure Exceeded 27-10 - Implausible Signal - Intermittent
                    • frjd
                      • Jul 2004
                      • 26
                      This also point to the MAF beeing the problem.
                      But what the hell is a MAF???
                      Found it: http://s2central.net/ds_G70.html
                      • A6 2,7Biturbo
                        • May 2005
                        • 398
                        • Country: Belgium
                        #26
                        Friend of mine had same problems with his S4 2.7T...
                        Replaced MAF and problems were gone...
                        Many MAF's fail these days, especially those on turbodiesels...
                        Bosch knows about this problem(price dropping of MAF's) but doensn't seem to come with a solution...
                        Glenn
                        • audiman
                          • 4827
                          The Mafs on Tdi's and the later type S4 ones are totally different. On the later cars they can be unplugged and the ECU will ignore them. Cant do that with the ice age technology on the S2
                          Tom C - www.rcmr.co.uk
                          Audi UR Quattro
                          Audi 100 C3 2.0 5 cyl 115ps
                          Audi B5 RS4 645ps 911nm
                          • A6 2,7Biturbo
                            • May 2005
                            • 398
                            • Country: Belgium
                            #28
                            What's of an MAF for the S2 anyway???
                            Glenn
                            • audiman
                              • 4827
                              Huh?
                              Audi UR Quattro
                              • A6 2,7Biturbo
                                • May 2005
                                • 398
                                • Country: Belgium
                                #30
                                What's price of an Maf for an S2 I mean...
                                Typed a bit to quick there...
                                Glenn
