If the lines are to narrow and the ammount is limited the pressure will also drop. It's like a voltage drop with too thin wires and high current. Now I'm relaying the pump to see if there is a difference. After that I will look to the lines.
Relayed and I got a little more. Now I got 5.6-5.7bar @1.5bar boost at almost 7000rpm. Looks like the boost is also a little higher. Could this be it or am I a bit optmistic or paranoid
