Ive been helping jim, human joist chase the boost cut he gets in 6th under load. Im now confident the system is leak free. However doing output tests and the n75 does not click at all.
The wiring looks good and jim is going to get the milti meter out.
I have a brand new one from a 1.8t. Two questions will it fit?
Failing thar has anyone had one fail causing these symptoms?
It is giving an overboost code which i guess it is if wgfv isnt opening.
