n75 wgfv.
  • Monkeymagic
    • Mar 2012
    • 3419
    n75 wgfv.
    Ive been helping jim, human joist chase the boost cut he gets in 6th under load. Im now confident the system is leak free. However doing output tests and the n75 does not click at all.
    The wiring looks good and jim is going to get the milti meter out.
    I have a brand new one from a 1.8t. Two questions will it fit?
    Failing thar has anyone had one fail causing these symptoms?
    It is giving an overboost code which i guess it is if wgfv isnt opening.
    Are the hoses hooked up properly?
    N75 info post: http://forums.quattroworld.com/s4s6/msgs/20987.phtml
      In not sure it will fit well but will likely just be orientation on the connector will be wrong
      • Monkeymagic
        • Mar 2012
        • 3419
        Its plumbed up correctly the fact it doesnt respond to vcds would suggest a wiring or valve fault..
        • Monkeymagic
          • Mar 2012
          • 3419
          Today i swapped jims mfts for him. We noticed whilst the car was sat with ignition on the wgfv was occasionally clicking on its own??
            If you snap the throttle open and closed at idle it should click.
            Possibly his one is actually stuck open so the waste gate isn't opening.
            • Monkeymagic
              • Mar 2012
              • 3419
              So activating the tps should cause it to click. I will have a look thankyou.
              I believe jims is actually overboosting rather than a leak as before.
                Originally posted by Monkeymagic
                ..I believe jims is actually overboosting rather than a leak as before.
                Overboosting is a sign that it isn't plumbed up properly, at least to the wastegate. But you say that it is so I don't know what the issue is.
                • Monkeymagic
                  • Mar 2012
                  • 3419
                  I have asked jim to triple check as per the diagram... ill let you all know.
                    You can also run the output tests using a blink tester. You have to wire up on the diagnostic connector put ignition on and then break and make the connection. Then trigger the output tests using the throttle valve to trigger the tests which which will check the ISV, injectors, WGFV etc.
                    You dont need much to do this, I keep one in my glove box which is a few cables, led, resistor and a button
                      Just realised you said you have already run output tests
                      • Monkeymagic
                        • Mar 2012
                        • 3419
                        I did they all function with the exception of the n75.
                        • Mikes2
                          • 1704
                          i had this on a friends ABY. the wiring was broken between the valve and the ecu. Fortunately there is a connector close to the valve below the headlamp and that's where the break was.
                          Mike
                          http://www.s2-audi.co.uk
                          • Monkeymagic
                            • Mar 2012
                            • 3419
                            We will check the wiring tomorrow. I have a new n75 from a 1.8t part number 06a 906 283 e.
                            Its fits the s2 loom and is visually the same. The resistance range is 25 to 35 ohms from what i have read.
                            I will try plugging it into the loom and see if it reacts to the output tests.
                            • Human Joist
                              • Nov 2012
                              • 189
                              Right. Steve has just brought round a working N75. It does not click when activated through VCDS so it appears I have a wiring issue. I will check it's orientation later. But with my multimeter I am getting 14.6 from terminal 1 so I have power from battery. The other is giving mass volts at over 23 at terminal 2. I understood this should be coming from the ecu. What should this be reading, any help appreciated to sort this as I am still getting boost cuts
