Boost stops at 1.4bar - N75?
    #286
    If you have G40 at the cam sprocket then it doesn't need to be separately aligned... G4 is indeed the crank ref sensor - the G40 & G4 pulses should arrive at the same time every other crank rotation... if they are far out of whack you don't even get an engine start so you should be fine although there is great confidence in actually seeing it.
    My gut feel is an air leak on this one - you need the bungs and a methodical approach to check everything.
    Have you checked for a torn WG diaphragm ?
    Might there by a hole in the intercooler that has been overlooked ?
    Check you have good solid 5V at the throttle pot and the altitude sensor as well - should be a red wire from memory on each of those when key is ON.
      • 4754
      Originally posted by hunker7
      AAH,AAN,ABC run the same fuel pump, so that can't be the problem.
      According to your above quote fuel pumps are the same.How did you come to that conclusion?It's of interest to me as i have AAH and ACK fuel pumps and could use as a spare for my AAN. Cheers.
        #288
        A quick check on the parts system will confirm.
          • 4754
          and i can do that at the click of a finger.........not, and don't know where to look.
            #290
            I was talking to myself lol. Will look it up tomorrow unless someone beats me to it.
            • hunker7
              • Mar 2014
              • 3487
              #291
              Says AAN, ABC and AAH runs the same pump.
              '93 Audi UrS4 Avant
              '15 Audi A7 quattro 3.0 TDI
                #292
                They do - just checked with by best girl 'KATE' lol
                • mastermind
                  • Jan 2005
                  • 244
                  • Country: South Africa
                  #293
                  If this happened after changing or working on the cams then as Paul mentioned check the mechanical timing.
                  Hope you get sorted soon.
                  The Red Baron
                  (R)S2 spec, 034 GT3071
                  Wagner Short Intake and Intercooler
                  Whiteline, Custom Shocks with external reservoirs
                  8pot calipers with A8 discs
                  Vems
                  • hunker7
                    • Mar 2014
                    • 3487
                    #294
                    On last couple of pages you can see what was wrong
                    '93 Audi UrS4 Avant
