Hi. I have a problem, my AAN won't boost past 1.4 bar (gauge), sometimes will tick to 1.5 and that's it. As before, it juddered when reaching 1.4/1.5, after I changed fuel lines, it just stops boosting, but runs without any problems otherwise. Before I had vacuum in the tank.
Just checked all the usual hoses that might have cracks, nothing, refitted them with new fasteners. I did notice oil in Michelin man hose
No error codes coming up either.
After reading on here and other places, N75 can be tested by removing middle vacuum line, and it should boost past 1.5 if faulty, correct me if I'm wrong, and if electric plug is removed I shouldn't see more than 0.4 bar?
Thanks a lot for help in advance
P.S. Don't be harsh, this is my first Turbo car
