Boost stops at 1.4bar - N75?
  • geneandbolly
    • Sep 2013
    • 1356
    Originally posted by hunker7
    NO!!! ...ok, I am actually considering it. But I hate giving my car to people
    just do it and be done with it.
    wasn't there someone recommended in your area that you can trust with it?
    1997 Audi S6 - The Purple Helmet!
    • hunker7
      • Mar 2014
      • 3487
      #257
      Surrey i think, not really local 120 mile round trip.
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
      • geneandbolly
        • Sep 2013
        • 1356
        ouch - that's a bit of a hike!!
        IS THERE ANYONE OUT THERE WHO CAN RECOMMEND A DECENT MECHANIC IN JANIS' AREA??
        • hunker7
          • Mar 2014
          • 3487
          #259
          I opened a thread asking, but only recommendation I got was Kim Collins from this end of the country, and ideally like to sort it out before I am off to uni on 20th
          '93 Audi UrS4 Avant
          • david1980
            • May 2014
            • 1025
            Kim Collins will cost the earth.
            You would be better taking it to a kind forum member since it still drives and plying them with copious amounts of tea and biscuits (or alcohol depending on how troublesome it turns out to be)
            • hunker7
              • Mar 2014
              • 3487
              #261
              What i don't get is how by moving timing by 1 tooth it didn't change at all. If it was right the first time, then it should be running even worse.
              '93 Audi UrS4 Avant
              • Rikki Kitto
                • Feb 2010
                • 6276
                Drive up to VRS at Northampton, 60 miles away fair prices and know these cars inside out Best thing I've done so far
                  Take the motor fuses out or disconnect the battery to clear the ecu.
                  And
                  Did you do this yet?
                  Originally posted by newsh
                  And do the check where you run it with the N75 disconnected so you get an idea of how much boost control the ECU is actually doing.
                  We need to know the difference in boost between N75 connected and N75 disconnected.
                  • hunker7
                    • Mar 2014
                    • 3487
                    #264
                    0.9 bar with N75 connected, 0.5 bar with N75 disconnected. I did get it to tick over to 1 bar in 5th gear @WOT.
                    Fair enough, let's say I have a boost leak (making the test thing now), but how is it possible that nothing changes when moving timing by one tooth?
                    '93 Audi UrS4 Avant
                      Because boost leak >>>>> one tooth correction.
                      What kind of boost gauge are you running again?
                      • hunker7
                        • Mar 2014
                        • 3487
                        #266
                        The factory fitted one.
                        '93 Audi UrS4 Avant
                          Makes no sense then. The factory digital boost gauge reads ABSOLUTE pressure, i.e. zero boost = about 1.01 BAR. So 0.9 and 0.5 Bar = vacuum, no boost at all. Max boost = 2.2 Bar (around 17 psig).
                          I'm off to London this evening for a holiday. Too bad I won't have the time to visit you and try to sort this in person. It's going to be something simple. What, I don't know.
                          • hunker7
                            • Mar 2014
                            • 3487
                            #268
                            I reckon it will be a boost leak, has to be. I am working next two days, but will get boost test done asap.
                            It goes to 0.9 then drops to 0.8 push it a bit more and goes back to 0.9.
                            '93 Audi UrS4 Avant
                            • hunker7
                              • Mar 2014
                              • 3487
                              #269
                              I am talking gauge not absolute pressure.
                              '93 Audi UrS4 Avant
                                @Dave. He's already subtracting the 1Bar atmospheric, we had all the confusion relating to this issue earlier in the thread. Ever since about page 3 he's been talking in terms of pressure of boost.
                                Anyway Janis, we now know for sure that the ECU is attempting to control boost, I'd be tempted to try the original WGFV again now just to see if you get the same numbers. In any case it seems the timing correction has had an effect, before I don't think you were seeing more than 0.8Bar (of boost) now we have 0.9 and even 1 Bar which is almost the mythical 1.1/1.2 (all be it at WOT in top gear).
                                One thing to bear in mind is that the factory URS boost gauge runs from the MAP sensor and a leak in the line to the ECU or even inside the ECU, will change the numbers quite a bit.
                                We've now fixed so many little problems and faults that we must be getting really close now..
