Boost stops at 1.4bar - N75?
  • hunker7
    • Mar 2014
    • 3487
    #181
    List of things I've tried.
    • Boost test (leaks fixed)
    • Checked all clips
    • Checked N75
    • Done output test
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • hunker7
      • Mar 2014
      • 3487
      #182
      Just checked the ECU, that is all fine too.
      MAP sensor isn't dead as it reads 1025mbar and TPS works fine too.
      Only thing I can do is leak test it again.
      I have noticed that car runs rough when idling. Gear-stick is visibly shaking, and if you put hands on the dash the whole car shakes. Nothing like that in my dad's Octy, can't even feel the engine running on his... don't know if that's how it should be, or, knock sensor is half dead and limits the boost.
      '93 Audi UrS4 Avant
      • hunker7
        • Mar 2014
        • 3487
        #183
        So, I might have found the problem. Looked at one of the UrS4boy write ups about altitude sensor, and Bentley manual says
        What the Bentley Manual says about the F96 is: with the three pin connector disconnected and with the wire bale up and the notch in the connector down, the three female connector pins are, left to right, 1, 2 and 3. With the ignition on, you should get 4.5 to 5.5 volts between pins 1 and 3 and pins 2 and 3, if not, there is a voltage issue related to the ECU. The only mention of ohms is 1 ohm maximum.
        Between pins 2 and 3 I am getting 5v, but pins 1 and 3 it's only 3.98v.
        '93 Audi UrS4 Avant
        • mike74
          • Apr 2014
          • 615
          try unplugging the lambda sensor when idling and see if its any different. did you ever check out the altitude sensor btw?
          • hunker7
            • Mar 2014
            • 3487
            #185
            Look above
            '93 Audi UrS4 Avant
            • mike74
              • Apr 2014
              • 615
              beat me to it!
              • hunker7
                • Mar 2014
                • 3487
                #187
                beat me to it!
                What now? It says there is problem with ECU voltage, is it fixable?
                '93 Audi UrS4 Avant
                • mike74
                  • Apr 2014
                  • 615
                  Not sure about the voltages im afraid. I just checked mine out using the resistance between pins 1+2 and found it was waaay above 1200 ohms. have a search on here and im sure you'll find some info
                  • hunker7
                    • Mar 2014
                    • 3487
                    #189
                    About that, I couldn't get resistance reading between 1 and 3, and between 2 and 3 it was something like 1080 Ohms
                    '93 Audi UrS4 Avant
                    • mike74
                      • Apr 2014
                      • 615
                      in fact here's the post that helped me sort my one out. its really easy to do if not a little fiddly getting the resistance correct (trial + error...lots of errors )
                      • hunker7
                        • Mar 2014
                        • 3487
                        #191
                        http://www.s2forum.com/forum/showthr...ic+ohms&page=2
                        Thanks buddy. I've checked the sensor itself
                        Across 1 and 2: 1290 ohm
                        Across 1 and 3: 2850 ohm
                        Across 2 and 3: 2400 ohm
                        That means the sensor itself is fine. But ECU isn't giving the right voltage to the sensor, is that it?
                        '93 Audi UrS4 Avant
                        • mike74
                          • Apr 2014
                          • 615
                          Not sure mate. It might still be worthwhile 'adjusting' it so resistance between 1+2 is LESS than 1200 ohms (just a smidge). I set mine to 1180 ohms and regained my missing 5psi boost.
                          • hunker7
                            • Mar 2014
                            • 3487
                            #193
                            ...on my way to do that
                            '93 Audi UrS4 Avant
                            • hunker7
                              • Mar 2014
                              • 3487
                              #194
                              I got mine down to 1150ohms, see if it works, if it does, will take my time to set it to just under 1200ohms
                              Wish me luck
                              '93 Audi UrS4 Avant
                                Wow. Did not know that. As I was reading, I was thinking, how did I miss this? Then I checked the date of the post. 2004. Okay, not crazy. I only showed up here in Feb. 2006.
                                Good info. Going to steal it and add it to my F96 post.
                                Thanks.
