Hi all, i hope somebody can help. My 20v aby keep eating turbos like sausages for breakfast , 3 and counting. First standard s2, then volvo k24 setup and now k27 hybrid. All happened within 100-150miles. Basically after you floor it, turbo start making noise as it's blades touching walls. It went for rebuild, hot side seals was blown and bearing eaten. After installing new one same happened for k27, turbo still in the car but it's gone, start sweating oil through hot side and oily whit smoke. I have no idea what it is apart from that is something wrong with oil pressure, i plugged mechanical oil pressure today thinking that there will be none, but now i'm thinking maybe it's to high! Maybe some restrictor needed for turbo feed line?
There is a video
Engine hot, you will hear fan kick in. When start from cold showing 6bar
Engine spec:
Hybrid k27
Rs2 exhaust manifold
3" all the way
440 green giants
New n75
New dump valve
Generic map prj 1.8 bar
Any thoughts guys? As i can't afford to spend more on turbos!
There is a video
Engine spec:
Hybrid k27
3" all the way
440 green giants
New n75
New dump valve
