Originally posted by S2central.net
Are you completely sure
Test 1: Isolated throttle body
The purpose of Test 1 is to test all hoses in the intake system with the exception of the throttle body hose. This test isolates the cylinders and tests most of the intake hoses in one go. Crankcase blow-by can affect the other tests so this element is eliminated.
Start by removing the hose from the intake pipe as shown in the photo above.
Insert the large solid bung as shown above. Tighten the hose clamp to secure in position.
This gives access to the breather pipe The rubber hose that links the rigid pipe coming from the camshaft cover to the solid pipe that emerges from the turbo compressor feed hose. The breather hose needs plugging to prevent pressurisation of the crankcase. All users who have purchased a pressure kit PKIT80/60 will receive a free bung to add to their kits when they have been manufactured.
For now, plug this hose using something suitable like a ½†socket drive extension as shown.
Now, the pressure adapter can be fitted to the hose that connectos to the MAF. The MAF (Mass Air Flow meter) is attached to the airbox which contains the airfilter. Note: photos used in this sequence were of a car with a non-standard airbox and will be updated in due course. It is worth attaching the pressure adapter last as it frees valuable acces whilst making the other connections. When fitted, tighten up the hose clip to secure.
Now that all elements are in place, pressurise the system (see notes). High pressure is not required for finding leaks. Pressurise the system to around 7-10psi or 0.5 bar. Exact pressure is not needed as leaks will normally be indicated by a hissing sound of escaping air. Very slow pressure decay is not a good indicator of a serious leak and is the result of a leak at very low flow rate. It will be difficult to find such a leak and if extremely small is unlikely to cause any running problems.
If a hissing sound is heard, a leak will be easy to trace. Pinpointing may require a soapy solution over the suspect area.
Replace suspect hose as rubber hose cannot be reliably repaired. Repeat test to see if there are any other leaks.
Paul we can put my shock absorber type spring in yours and pressure test. Dont drive it tho!! LOL
