Idle wont keep stady when cold?
  • Jonas_R
    • 3780
    • Country: Denmark
    When my car is cold (1992 s2 coupe) the idle goes from around 1000-700/600 rpm's. When warm it stays around 800/900 rpm's, cant remember if it is 800 or 900.
    Any idea what can cause this?
    Did put a HKS filter directly on the MAF see pic, if this could have any effekt?
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • 91_S2
    • 612
    You might want to check your idle stabilizer valve. Clean it with carb or brake cleaner. Relubricate it. The ISV is back by the firewall. It is a small cylindrical part right behind the throttle body.
    • S2 Ant
      • 3682
      Also check any vacuum hoses as i believe they would also cause an idle problem
      Ant
      2011 Kawasaki Z1000
      • Lee
        • 1512
        It was the connector on the ISV causing my idle problems. Cleaned the contacts and all was better at idle.
        Designun Limited....
        • Ski
          • 2591
          Hi, i seem to have the same problem and its growing worse, idles at 1100, sometimes dropes after a rev or two.
          As you all know im a mechanic GOD.. when i sleep, but during the day i seem to forget everything regarding mechanics :/ honest
          can i clean this ISV with the same stuff i clean my MAF ? (i forgot the name of that solution again)
          And, I dont suppose anyone has a picture of where this is located for me otherwise i will start unscrewing random objects and cause more harm then good
          ABY Coupe
          • Ski
            • 2591
            also what do i re-lubricate it with ?
            ABY Coupe
            • WabTheKing
              • May 2004
              • 2567
              answer above: duno
              answer above: here
              • RIX
                • Jul 2004
                • 229
                • Country: Denmark
                yes you can,it´s called IPA,or at leats i clean it in that.
                Regards
                RIX
                • rotoryboy
                  • May 2004
                  • 3281
                  That's the stuff
                  I.P.A
                  Mark
                  Race Clio RS197
                  S2 Coupe ABY (Green) - RIP
                  S2 Coupe ABY (Blue) - Sold
                  • Ski
                    • 2591
                    yup still got some ipa left.
                    Thanx for the Pic, ive located this strange looking once-unidentified object
                    So i just unplug the hydrolic looking device and soak it in ipa? or do i just clean the electronic connetion to it?
                    ABY Coupe
                    • WabTheKing
                      • May 2004
                      • 2567
                      what about this IPA? ive used this to flush my system before
                      • rotoryboy
                        • May 2004
                        • 3281
                        Far more fun, just don't mix them up,lol.
                        Mark
                        Race Clio RS197
                        • Ski
                          • 2591
                          Do i just unplug the hydrolic looking device and soak it in ipa? or do i just clean the electronic connetion to it?
                          ABY Coupe
                          • WabTheKing
                            • May 2004
                            • 2567
                            take it off, clean the connections, and spray/rince the inside i would imagine, ive done it with wd40 in the past. just air pipes on it so nothing to leak, make sure you tighten them jubby clips up tho when you put it back on otherwise you will find yourself with a boost leak my friend
                            • Ski
                              • 2591
                              ohh.. cool.. but actually drownding it in ipa is a no no?
                              ABY Coupe
