Dissapointing lag
3071R with standard cams is surge-o-rama, you are going to have the same spool as a 0.82 trying to limit the surge.
Also, 450hp is not really possible on a 0.63 71R.Comment
What difference does the gear you are in make typically. I was taking the numbers off my dyno print out and i noticed it was mapped in 4th. I would expect the calculations in the software used by the mapper to take the gear out of the equation but Im no expert in the subject.Comment
On the dyno the gear does not make any difference at all.What difference does the gear you are in make typically. I was taking the numbers off my dyno print out and i noticed it was mapped in 4th. I would expect the calculations in the software used by the mapper to take the gear out of the equation but Im no expert in the subject.Comment
I have a theory that my lag could be to do with my twin pass intercooler being too restrictive and giving too big a pressure drop although I would imagine this to have more effect at high revs than in spool up. I've decided I'm getting a bigger one anyway with improved flow as my inlet temps are too high, I'll post the results when available.Comment
Get a differential pressure gauge on it with one taping on each side of the intercooler to see what restrictions it causes.Comment
