There is no voltage at the injector fuse (ignition on, or cranking)
3B no start help
Fuel pump relay has 2 sets of contacts, one set powers the fuel pump via fuse 13 and lambda via S25. The other set of contacts powers the injectors via fuse S28 and the N71/75/80 via fuse 24Last edited by newsh; 30 August 2014, 20:37.Comment
Can you check for power at S24?Comment
Just separated the electronic ground and power ground under the intake manifold as apparently malfunctions can occur.
I am assuming fuel pump fuse is getting power as I have fuel pressure.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
If you've got the fuel pump running but no injectors then it looks like you've lost the wire from pin 87a on the fuel pump relay to one or both of the 2 fuses S28 and S24Comment
Thats why its a bit odd as its the same signal out of the ecu!
If you can tell which contacts are which you may me able to close the appropriate set to temporarily prove its the issue or not. You will need to pry the cover of one of the relays.Comment
Hm, just the connection from Fuel pump relay to fuse S28 missing then, if the fuel pump is running when cranking, which I guess it is as you have fuel pressure!Comment
n75, isv and carbon canister all click on output, so must be as you say.
Really weird, I have not been in the fuse box, or under!Current-2004 Impreza PPP wagon
