The ECU assumes that there is 4 Bar of pressure available across the injector(s) when it selects what it thinks is the appropriate injector duty cycle (i.e. the period of time that the injectors are cycled open) for the given situation, e.g. RPM and load. As I understand it, when the car is NOT at WOT, there is feed back from the O2 lambda sensor that the ECU will use to adjust (increase in this case) the duty cycle to correct the lack of fuel that less than 4 Bar across the injector would cause. However, there are limitations on that adjustment capability. At WOT, the O2 sensor signal is ignored by the ECU so adjustments are NOT possible.
prj will correct me where I am wrong.
