Stroker cambelt guide
  • #31
    Pictures replaced.
    • #32
      • #33
        Ill got the rs2 waterpump
        Rs2 150 tooth belt
        Custom tensioner
        Lower Belt guard from a t4 acv eurovan
        Cut it and plastic weld the upper guard from a 16v kr
        Got no room for the longer nose on a 3B waterpump thats gona hit my intercooler in my b2 typ85
        Does anyone know what tensioner is used in the pic, described as "custom tensioner"?
        ABY S2 stroker (work in progress)
        B5 1.8T quattro
        B4 2.3 (decommissioned)
        • #34
          Its some aftermarket pulley that fits in the stock location on the oil pump...I have it the same but I also made my custom stroker belt tensioner. You can check it in my build topic.
          Audi Coupe Quattro 2.3 20V
          • #35
            Do you have a link to your build thread? I can't seem to fine it.
            B5 1.8T quattro
            • #36
              Here you can see my custom tensioner bracket with pulley. It helps to prevent belt slapping.
              • #37
                That looks perfect and would be ideal on my block as well.
                Do you know what roller you used?
                B5 1.8T quattro
                • #38
                  Not by memory, but it was some regular roller that could be bought at the shop.
