Anyone tried a different n75 valve on there cars
  • Monkeymagic
    • Mar 2012
    • 3419
    I know I have a genuine 1.8t one in a box that I bought for mine.. however in my experience they rarely fail.. have you cleared.the fault to ensure its not a ghost code??
    • Mikes2
      • 1704
      I don't think you'll find this valve in the other cars you mention. It's a wgfv so you certainly won't find it on an ADR engine which is not a turbo engine. It can be tested using Vag Com / VCDS in the output tests. I've seen a broken wiring loom causing this fault - it sits behind the right side headlamp so easy to check.
      Mike
      http://www.s2-audi.co.uk
      • B5NUT
        • Sep 2021
        • 1071
        Yes, cleared the codes and this one came back. I've got a 1.8T (AEB) n75 in front of me purchased it by mistake as the numbers between the two engines are the same it's jus the AEB version also has a letter on the end. The problem with the AEB valve is it has a newer 2 pin plug on it, and don't want to start cutting into the car harness for something that may not work. At least I know the ADR version uses the same plug.
          Quick test for the valve, engine at idle reach down behind headlight and place fingers on valve, quickly give throttle a big blip, you should feel the valve clicking.
          When I got my first coupe back in ‘02? the valve was partly unplugged, was a nice surprise when properly plugged in.
          • Mikes2
            • 1704
            034 133 517 ? That's a carbon canister N80 valve. Not the part being referred to here.
            Mike
            • Monkeymagic
              • Mar 2012
              • 3419
              As stated above an output test will see if the valve is clicking away..on my mates ABY it was down to crudded up earth or the connection to the oil pressure sender I can't remember exactly
                N75 is 034906283 I think
                • B5NUT
                  • Sep 2021
                  • 1071
                  Your right. I'm looking at the wrong valve, it's this part number 034906283K
                  • andyg plym
                    • Nov 2006
                    • 4646
                    Had a few issues with mine recently where it was sticking causing problems tried a cheap Chinese £10 special and a waste of time. In the end got a genuine new one from a forum member but did find Quattro corner also sells them
                      • Dec 2017
                      • 5984
                      I think Bertman had a couple for sale recently
                      • B5NUT
                        • Sep 2021
                        • 1071
                        So I now know why I'm getting the error code. It's not plugged in..
                        Found the cable pushed into the headlight behind the black cover.
                        So why the hell would you unplug the valve unless it faulty?
                        • Mikes2
                          • 1704
                          If the car has ever been to superchips, it was common to see this disconnected
                          Mike
                          • B5NUT
                            • Sep 2021
                            • 1071
                            What will that achieve on the S2 more power? From the few sites I've read about unplugging the n75 valve it will limit the boost but could help if you have a vacuum leak.
                            • B5NUT
                              • Sep 2021
                              • 1071
                              So I've not tested the N75 yet but not sure there is much point. As shown in the picture below there is a crack in the housing, and it's not holding air or vacuum, so I guess it replacement time.
                              Also connecting the plug to the N75 valve clears the fault code, so I know it's not a wiring fault, there must be vacuum leaks in the system or it's just at the point below.
                              • B5NUT
                                • Sep 2021
                                • 1071
                                I called superchips but they could not help. The company went bust last year, and they have been bought out. The new owners have dropped all of there franchise and they now only have records of remaps for the last 12 months. They also don't remap the S2 anymore.
