What's the best way to check for detonation?
    Can I log it in Vagcom? Sensor, amp and headphones?
    iPhone app?
  • andy10v
    • 5996
    Listen with detcans.
    Marc did a good article one how to make a set cheaply
    http://www.efiexpress.com/catalog/ar...?articles_id=4
    I think a few people on here have this setup.
    Sold ABY-stock
    • 220bhp
      • 2578
      • Home: United Kingdom
      Speak to dimitri I am sure he used head phones when mapping my car.
      • gnutz2
        • Aug 2006
        • 928
        + 1 to headphones, and its very cheap to do.
        I have this http://www.phormula.com/KnockMonitor-KS-4.aspx but past about 6500rpm all i pick up is noise.
        The ONLY S2 Golf!
        http://www.s2forum.com/forum/showthread.php?t=19402
        10.42@138mph
        https://m.youtube.com/watch?v=0wnkkOfFpXg
          So do I need to add a knock sensor or just use one of the ones that's there? And won't the ecu restrict boost if the KS is disconnected?
            The knock sensor is essentially a microphone that picks up audio frequency which is filtered and processed by the ECU... I don't think the ECU throws up a fault because a KS is unplugged - its because it sees zero signal where it expects to be hearing the engine running... Dmitri can confirm or correct me on that... Its something I will be needing to look into on the ESIM project but anyway.
            You could just connect a suitable audio amplifier (working at microphone levels of input) across the KS output and listen to that on headphones - a common solution is to just hook up the mic input of a PC and use audio software on that to relay the signal to the headphone jack.
            The KS wiring is signal, 0V and screen on pins 1-2-3 respectively.
              High impedance of microphone connected in parallel to the KS means the ECU still hears signal as normal... some kind of cable adapter built around JPT-3 connector(s) would seem to be the way to go... easy to make with some robust screened audio cable and terminate in a 3.5mm jack at the PC input
