Hello!
My English is not very good, but i try.
I need some help, i put my s2 1994 down into pieces in 2008, today i have put it 99% together.
Im into putting a new ecu to it and cutting the old cables away, i have located the most cables under the bonnet, but there is 1 contact and 3 pipes/hoses i dont know what they do.
The big one is the TPS, do someone know how the pins are connected?
Also, i dont know where the smaller 2pin contact connects to, i guess its for the boost solenoid, everything contacts seems to be in matching colors, but this one is not?
Contact is pure black, but boost solenoid is black and brown?
I have no brown 2pin female contact at all.
And also the vakum hooses/pipes, someone know what they (2 & 3) are for and where they should be conntected?
No. 1, is it some kind of valve for backpressure?
What does it do and the hoses/pipes do and what does it connect to?
This is already cut:
Injectors
Cam sync
Water temp on back of cylhead
Airmassmeter
lambdas
ignition coils
igition modules
Vroom vroom!
Injectors
Cam sync
Airmassmeter
lambdas
ignition coils
igition modules
Vroom vroom!
Sorry.
