There is no signal it's just a switch, it's open (normal condition) and closed in (over temp), that's why you can just cut the wire or unplug it and the ECU is none the wiser.
Many people have done this on ABY when the MTFS goes **** up and reduces you to spring boost.
You can also wire a switch in to give you a “Valet mode” as no code is stored in the ECU when the switch is opened again.
