MFTS delete?
  • driftin jo
    • Sep 2007
    • 2222
    Originally posted by UrS4boy
    034919369C is the AAR/AAN/ABY/ADU F76 MFTS.
    The F76 Multifunction temperature sender has different functions in the ABY and ADU than the AAN. For all three, the MFTS is the sender for the temperature gauge in the instrument cluster. On the ABY/ADU, the MFTS is also connected to the ECU via pin 46 of the T55 ECU connector. Using this pin as a high temp alarm (> 119 C) - the ECU cuts off active boost control as a safety measure. Eliminating that signal might freak out the ECU.
    F76 MFTS info: http://forums.quattroworld.com/s4s6/msgs/22584.phtml
    There is no signal it's just a switch, it's open (normal condition) and closed in (over temp), that's why you can just cut the wire or unplug it and the ECU is none the wiser.
    Many people have done this on ABY when the MTFS goes **** up and reduces you to spring boost.
    You can also wire a switch in to give you a “Valet mode” as no code is stored in the ECU when the switch is opened again.
      Originally posted by driftin jo
      There is no signal it's just a switch, it's open (normal condition) and closed in (over temp), that's why you can just cut the wire or unplug it and the ECU is none the wiser. Many people have done this on ABY when the MTFS goes **** up and reduces you to spring boost. You can also wire a switch in to give you a “Valet mode” as no code is stored in the ECU when the switch is opened again.
      Thanks. Good to know. I'll add your info to my F76 MFTS info.
      • ralleyquattro
        • Oct 2007
        • 536
        • Home: Poland Current: Canada
        Originally posted by andy10v
        That would be good if its not mega expensive, if you can find the part number it would be great
        049 919 501E
        Less than $20
        www.quattro.ca
        B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
        B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
        • Laaf
          • Oct 2010
          • 275
          Originally posted by ralleyquattro
          Do you have a part number for the corresponding connector? And what spade connectors is to be used, same as in the F76 connector?
          • AndyP
            • 6049
            Also, what car is it off? Trying to find a supplier here in the UK
              049919501E seems to be C3 and B3 Audis including KV and 7A engines. 120 C, two pin, white, M10 x 1.
                Some part numbers:
                Behr 8.051.01
                FAE 32200F
                Meyle 100 919 0027
                • AndyP
                  • 6049
                  Originally posted by Error404
                  Some part numbers:
                  Behr 8.051.01
                  FAE 32200F
                  Meyle 100 919 0027
                  Thanks, found the Meyle one on Amazon for £11.50 delivered
                  • ralleyquattro
                    • Oct 2007
                    • 536
                    #24
                    In Canada all Coupe GT and 4000 quattro had them.
                    Hope this helps.
                    www.quattro.ca
                    • ralleyquattro
                      • Oct 2007
                      • 536
                      #25
                      7A uses the MFTS, where did you see that the 2-pin sensor was used on a 7A??
                      www.quattro.ca
                        Can't find it ATM, but I didn't make it up. I searched 049919501E under Local Market, A10Q, then ATP, All models. Lots of C3 and B3s come up. I don't find 7A now either, just KV for the ACOQ. (???) but I did see it.
                        I think.
                        • ralleyquattro
                          • Oct 2007
                          • 536
                          #27
                          I think.
                          No need for KATE, I can tell you from experience 7A uses MFTS just like 200/S2/S4/S6
                          Other B3, possible, but I also know that once Audi switched to 2.3 enignes (mid '87) the MFTS became standard across the board, it was used on the 1987.5 Coupe GT as well.
                          www.quattro.ca
                          • Ryss
                            • Nov 2009
                            • 233
                            • Country: South Africa
                            #28
                            I just so happen to working on this problem on my type 85 Quattro to which I am fitting a ABY motor, with after market ECU.
                            The type 85 (original engine was a KV) has an alarm and light that goes off on overheat and/or on low water level condition. To me it looks like both circuits are normally open,
                            But the light flashes continuously.
                            I can not find the problem. Electronics are not my strong point. Any suggestions?
                            I am using an additional temp sender from the back of the head in the water manifold as it has the same thread as the MFTS. Have not seen whether the resistance of this sender matches the OE sender.
                            Regards
                            Ryss
                            www.autostart.co.za
                            • AndyP
                              • 6049
                              Great service from Amazon, it's just arrived!! Ordered at 5.30pm, delivered at 11.50am next day
                              • Rikki Kitto
                                • Feb 2010
                                • 6276
                                This sounds like such a good move I've had nightmares with MFTS over the past couple of years and at £120 from Audi they need deleting
